Need help with SINGLE variable..
mastero
Hello
I am making a simple pressure sensor all works fine.
i get the output reading as XX.XXX on a 16x2 LCD
i want only the XX before the decimal to be displayed. Help please. :)
Dim Pressure as Single
displaypressure:
		Adcin 0, analogread
		pressure = analogread * 5.0 / 1024
		pressure = (pressure - 0.54) / 0.059
		Lcdcmdout LcdLine1Clear
		Lcdcmdout LcdLine1Home
		Lcdout "PRESSURE", ":", " ", " ", #pressure
Return
cheers
Mastero
Hello
displaypressure:
        Adcin 0, analogread
Return
cheers
Mastero
...deleted...
I would try to cast... example..
Dim DispPressure as word
displaypressure:
        Adcin 0, analogread
        pressure = (Pressure - 0.54) / 0.059
        DispPressure = Pressure
        Lcdout "PRESSURE", ":", " ", " ", #DispPressure
Return
That should get rid of the floating points..Untested ..Try it.
the pressure you are getting is an analog thing you want to convert it to a digital thing
try this:
  • int r(float f) {
  • int result = f;
  • return result; // You could just write "return f;" instead.
~~Cris
try this:
  • int r(float f) {
  • int result = f;
~~Cris
That is C This is Oshonsoft Basic forum.. Singes are new to the platform..
displaypressure:
        Adcin 0, analogread
Return
PERFECT :) Thanks
