Yes what do you really want to do with the card info?So, if I understand you correctly, you want to swipe a credit card, decode it, and use the info later to shop in online shops?
oh those ok, so there is no grounding required and both go to the L if the software can do that if I am interpreting this correctly.You are not seeing the bare wires connected and labeled GR.
No I am not going to steal the card info for use later on. If I wanted to do that I would just purchase a device for that.Yes what do you really want to do with the card info?
Not quite. The GR and L terminals connect to the two terminals of a magnetic read head. The R terminal should not connect to anything.oh those ok, so there is no grounding required and both go to the L if the software can do that if I am interpreting this correctly.
Well thats good to here.No I am not going to steal the card info for use later on. If I wanted to do that I would just purchase a device for that.
I am doing this to show the people at my comic book store how fun and educational electrical engineering is. So maybe they will get real jobs instead of living with there moms.
You could offset two or three heads to read more tracks.Something you may want to consider and think about. If you look at a few financial institution cards like credit cards for example the magnetic strip positions are all the same. The magnetic strips are all about .223" down from the tops of the cards. The strips all occupy about the same height also and that should be about .330". Financial cards are all formatted the same to a standard. Within that .330" top to bottom there are 3 tracks of data, each track being .110". What this means is that when reading data on a two or three track card your read head must remain in or on the track you are reading. Not for example like using a wand to read a bar code where we can just swipe the wand over the code. If you look back at the German in the early link reading the card note how he used a straight edge and worked along that edge. Readers that read strips on credit cards actually have three read heads in a single package.
All this really means if we use a hacked read head (from for example a cassette player) is that we can only read a single track and in the case of a multi track strip we need to remain within that track. Everything depends on the type strip you are reading.
Ron
Do they not store the amount of money used or that pulled from a server with her number?Much wider strip and I would venture a guess likely a single track with her name and unique number?
Huh? What's a POS system?
Ron
Usually 'Point Of Sale' - but 'Piece Of Sh*t' is sometimes used
Yep thats it. LOLUsually 'Point Of Sale' - but 'Piece Of Sh*t' is sometimes used
Seems cheep enough, but what would you use for software?Why to make simple thing complicated? Use USB card reader like this: https://www.ebay.com/itm/USB-Credit...418?pt=LH_DefaultDomain_0&hash=item45fb96ebda . I have similar in my store, I can read card even in notepad.
Swiping card is like entering info from keyboard.
