Hey all,
I need to light some leds when a remote circuit is switched on. The leds will be indicators in some "headgear", so I'm striving for maximum space savings.
The indicators I need to light will always be about 3 feet away from the circuit they're responding to, and will only be necessary then, so IR line of sight and obstruction shouldn't be a problem.
So basically, I need the equivelant of a wireless relay. I think I want to avoid RF because of the complicated receiver circuitry needed. But to be honest, I don't know a whole lot about IR modulation and receivers yet, so I don't know if IR would be as complicated. I'm guessing it wouldn't, by a couple simple mod/demod schematics I've seen.
So here's what I'm wondering about:
- Will the transmitted IR signal need to be modulated to avoid false triggers by sunlight or TV remotes or other IR sources?
- Will an IR demod or receiver circuit take up more space than an IC or two, or more than an rf receiver circuit?
- Can the circuit be effective with a simple IR led and IR phototransistor, IR led just turning on as the tx, and the phototransistor seeing the IR as the rx? This is where I'm worried about false triggering.
Also... The IR transmitter (or led) is going to get it's power from a brake light circuit in a vehicle. How can I tap the brake light circuit to get enough power for the IR tx/led without creating a short for the brake light circuit? The brake light is 12v, but I'm not sure what the IR led is rated, probably 2v. Is a series resistor enough for a voltage drop and a current limiter? I'm sure there's going to be math involved...
I'm in the process of learning electronics, although with no real "teacher" and a full time job and family, it's slowwwww going... I've run across this site a few times in the past year, so figured I'd join and ask a question now and then... Some of AudioGuru's comments have stopped me from attempting certain circuits I've found posted here, too...![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I appreciate any response!
