I had built this remote temperature sensor circuit and it works just fine...
Source – Maxim’s MAX6648/MAX6692 Datasheet
According to the datasheet I can increase remote accuracy if the IC temperature is kept at 85C, so I’m trying to add some sort of IC heater mechanism to this circuit. It just so happens that the OVERT pin is an open-collector that goes low when the IC is at 85C. So I thought I could use this signal to toggle a heater circuit. That way, the circuit would maintain the IC at 85C.
Here’s the solution I came up with...
I added a JFET to the circuit. This JFET will be bonded to the MAX6692 IC. The idea is that when OVERT is high (actually, just disconnected) there's 0V at the gate and current flows, heating the IC. When OVERT goes low at 85C (actually, just gets grounded,) 3.3V will turn the JFET off. When OVERT goes high, the 10K resistor, which used to be a pull-up, now has a new job of shunting the JFET and then current flows again.
The JFET I have in mind is a J113. Cutoff is 0.5V - 3V. The resistance across DS is 100 ohms. I figured I'll just connect a 9V battery right to the JFET and let it heat up. The JFET is rated at 400mW, but I'll be pumping 720mW into it. Hopefully, the fact that I turn it off at 85C will keep it from being destroyed, but I guess I just have to try it and see.
Does this make sense? Any and all thoughts are greatly appreciated. Thanks!
Maxim MAX6692 datasheet
https://www.electro-tech-online.com/custompdfs/2004/08/MAX6648-MAX6692.pdf
J113 JFET datasheet
J113 JFET datasheet
