Neeed help ``part1
kartulisupp
From this page **broken link removed**
I wanted to know when i will build 1 .Can i use for C1 a a 6.6volt capacitor or a 16v capacitor.
For C2which disk capacitor do i hav to use`????
disk capacitor 2kv 470pf
disk capaci. 2kv 330pf
disk capacitor 2kv 560pf
disk capacitor 2kv 270pf
cond. 680pf 10% 2kv
disk capacitor 3kv 820pf
also: c3000 1k also: c
capacitor also: c30
disk condensator
disc cap. 3kv 2.2n
disk capacitor 2kv 1200pf
disk capacitor 2kv 2200pf
disc capac.3kv 1.2n
disc capacitor 3kv 1.5n
disc capac. 3kv 1nf
disc capac. 3kv 2.2n
And from C3 which trimmer capacitor?????
2320-2
trimmer/variable capacitor (johanson manufacturing)
2320-3
2322-0g
2322-1g
2322-2g
2322-3g
27263
27271
27271sl
27283
27291sl
47273
5201
5401
5402
5501
5601
5641
8052
9301
9302
9304
9305
9315
9328
9341-2sl
9341-3sl
9341-5sl
9341-6sl
9341-8sl
9341-9sl
9342-14r1
9342-16r1
9343-17r1
9343-18r1
9343-19r1
9372
9374
9376
9385-1sl
9385-2sl
9385-3sl
9385-4sl
9401-0
9401-1
9402-0
9402-1
9402-2
9402-6
9410-5
9701-0
9701-1
9702-0
9702-1
9702-2
9702-6
9710-1
9710-5
ctz3e-10a-w1-pf
trimmer/variable capacitor (avx)
ctz3e-30c-w1-pf
variable capacitor trimmer capacitance m (avx)
ctz3e-40c-w1-pf
tzw4z1r5a001r00
trimmer cap, high power (murata)
TRIM10/5
trim capacitor 2-10pf
TRIM10P
TRIM22P
trim capacitor 4-20pf
TRIM30P
trim capacitor 3.3-33pf
TRIM100P
trim capacitor 7-100pf
TRIM39P
trim capacitor 5.5-40pf
TRIM65P
trim capacitor 5.5-65pf
TRIM80P
trim capacitor 5.5-80pf
and for C4 which disk capacitor????`
cond. 680pf 10% 2kv
capacitor also: c30
disk condensator
disc cap. 3kv 2.2n
disc capac.3kv 1.2n
disc capac. 3kv 1nf
C1 can be 6.6v or 16v.
C2 has to be 10nF or 0.01uF. As long as it's over around 3v it should be fine.
C4 is 4.7 pF As long as it's over around 3v it should be fine.
help ??????
R1-10K.
is it like a switch or a piece if it is just a piece how many W does it have to have????????????????????????????????????????????????
help ?????
For this construction!
For C1 the electric capacitor how many volts can it be?+
Can I use a 6.3 V or 16 V one?
The voltagew across C1 in the circuit is very low so either capacitor's voltage rating is fine.
The part you provided a link for is rated at 600V. a 100V capacitor will work the same, it will be smaller and it will probablybe less expensive.
LM3909 LED Flasher
Does anyone know where i can find something that i could use instead of this and would have the same effect???
for what i need it for
you could try a CMOS 555 which works down to 1.5V, although as the battery dies and the voltage drops it may have trouble. Also the max current from a 555 is 50mA and I'm sure the 3909 could source a great deal more.
