New Life For PICKIT 3 Stand Alone Programmer App?
Mike - K8LH
Just wondering if anyone has tried Jaakko Kairus' PICKITminus project to upgrade the Stand Alone Programming App' for their PICKIT 2 or PICKIT 3 to program many, many, almost all (?) PIC devices?
Also, back in 2020 I asked if there was a way to avoid buying an expensive PICKIT 4 to program an 18F27Q43. Recently, after studying Jaromir Sukuba's A-P Programmer code, I've been able to use a relatively inexpensive Arduino Nano clone to read/write/program 18FxxQ40, 18FxxQ41, and 18FxxQ43 devices in LVP (Low Voltage Programming) mode. Fun stuff but I could use a hand writing a Windows "front end" to manage file transfer to/from the Arduino.
Cheerful regards, Mike, K8LH
It's pretty easy to program PIC's, you just wiggle pins up and down, but why limit yourself to low voltage?.
Doing it with a processor (like the Arduino) makes it even easier, as it's far easier to 'wiggle pins' on a micro-controller than on a 'modern' PC - old PC's DOS and upto Win3.1 were fine, but after that things got more difficult.
My 'claim to fame' was writing the worlds first Windows PIC programming software, long before MicroChip ever did any, and I wrote it in Delphi 1.0 moving on from my earlier Turbo Pascal version. A good choice for you would probably be Lazaruz, which is essentially a free version of Delphi. Or Visual BASIC?.
Biggest problem with PIC programming software is the huge variety of different devices, along with a goodly number of different programming algorithms, this is why the PICkits continually download updates to their firmware as you switch between different devices. My first programmer software only supported one PIC, the 16C84 - which was the only electronically reprogrammable one at that time.
I got hold of a MC " snap " back on its first release, has been very useful ,(only LV PICs ) and at the time quite cheap 12 GBP i think. ( now 25+vat from Farnell ) I still use PK3 , for me the { debuging is essential }else{ none of my code would work }
I've used PICKITminus a couple of times now and so far it's worked ok on the few devices I've tried it on.
Because if you stick to LVP you don't need to create a programmable HV VPP generator, and you don't have to worry about applying an over-voltage to an incorrectly selected part. As Mike shows it makes the circuit a lot simpler.
You don't really need one anyway, the majority of PIC's use a similar voltage. Using HV programming saves resources on the PIC.
Yes, to use LVP on these more recent devices the MCLR pin must retain the MCLR function (you can't use MCLR as an input).
Last year I attempted to use an interrupt driven charge pump for HVP (8.3v output) but couldn't get into "program & verify" mode. I may try again.
I think more people might build projects that include a PIC microcontroller if they don't have to buy an expensive PICKIT 4 programmer for what may well be a "one off" project. For example, I made an Arduino 'sketch' that includes the PIC firmware as a const array to program the 16F18877 chip for the new version of Karen Orton's PICL/NIBL (SC/MP) computer (see below)(more info' here). Kind of a "Programmer to Go" using an Arduino Nano.
Stay safe, guys. Regards...
View attachment 136416View attachment 136417
Very nice :D
I remember SC/MP, but never heard of this emulator.
Wrote a lot of code back in the day on INS8070 and INS8073 with NIBL. Interesting part, could use
address pointer HW as a crude HW multiplier. It was a lot nicer than the COPS (with its non linear
addressing) I was writing for as well, but not as good as IMP16 or PACE. I still see SCAMP parts show
up on ebay. Built a programmable f() generator out of a INS8073. Wire wrap proto mess but worked
pretty good. A small team of us with Interface group tasked with building the lowest parts count terminal
when National introduced the single chip CRT controller INS8350 era, bipolar chip.
Regards, Dana.
Even the el cheapo SNAP isn't so "el cheapo" anymore. Seems prices have all gone up.
Maybe a better option is a Curiosity/Curiosity Nano board w/builtin programmer/debugger. They go on sale at MicrochipDirect now and then (devtool deals change every month). Or a decent PK3 clone...
I wonder if you could ' steal' the boards ICSP signals to drive an external device , you would have to remove or disable the attached micro i guess ... I had done it with a MC PIC24 Microstick
Both the Curiosity LPC (DM164137) and Curiosity HPC (DM164136) boards have an unpopulated 0.1" SIL ICSP pattern where you can install a header. The target on those is socketed, so no problems there... just pull it out and you get a PKOB4 programmer (LVP only).
The smaller Curiosity Nano boards also have an ICSP pattern, but there it's a 0.05" SIL pattern, and since the target micro on those is soldered on I don't know an easy way of disabling it short of removing it.
Mike - K8LH Did you try the PICKitMinus? And it works fine? A few years ago I took the PICKit2 firmware that Microchip made available and modified it to handle the newer chips that I was using, so I imagine what Jaakko did works. Modifying the firmware and/or the standalone app isn't difficult, but adding each new chip to the device file is time consuming.
Mike
Mike
Something wrong with my Pickit 3 and that's why I asked if anyone else had tried PICKitMinus...
Just found my Chinese PICKIT 3 clone and I'm happy to report that PICKITminus works great. I'm very excited because it allows me to program a number of newer chips that would normally require the relatively expensive PICKIT 4.
The 18F27Q43 is indeed a nice part. I've got an assembly language template for MPLABX v5.35 and MPASM v5.87 that includes PMD and UART1 initialization and drivers as well as some test code to drive a Charlieplexed LED display one segment at a time (~140-Hz refresh rate). I'd like to explore the DMA peripheral next...
