Hi Peter,
I can see you must have spent some time tracing out the wiring. I can't find the bit of information on you diagrams that I needed. That is the voltage at the point J1-9 on the downloaded diagram which I think is connection 5 on the PC board on your diagram. This is where wire 224 connects to the PC board. This should be at about 12 - 14 volts (Battery voltage) This is required to initially energise the rotor and is the supply to the PC board electronics.. If the voltage is correct at that point then I think the fault is on the PC board.. I think that the PC board will be very expensive so it might be worth trying to find a specialist company that repairs generator set to confirm that diagnosis before ordering PC board.
Les.
Les.
