I was wondering if it was possible to use two identical NPN transistors instead of an NPN-PNP pair.
I was thinking that if you could flip the signal, apply the original signal to one NPN and apply the inverted signal to the second NPN and gave both a slight bias current, you could do it.
I just wanted some feedback as to the feasibility of the idea.
If it won't work, I guess I'll order some PNP transistors or just make a class A amp.
Thanks in advance!
P.S. I'll add some schematics later if needed.
Thanks in advance!
