ON/OFF pulse switch???
cobra1
Didnt know what to title this as, im looking for something that requires a single quick pulse to activate a switch.
once the switch has been activated i dont want it to consume any more power so a relay is out, looked at thyrister but they require a continuous current to stay on.
the switch is connected to a timer, every 3 hours it sends a pulse, this will activate the switch, the switch is a double throw, i.e it has 2 outputs
so as an example i need it to do the following,
3 hours elapsed, pulse, switches to device A
3 hours elapsed, pulse, switches to device B
anyone any ideas???
555 and 4017 can fulfill you requirement.
You just use only Two channels of 4017, so that it can toggle one and other for each pulse.
But i am not sure about 3 hours time delay using 555 timer.
Hi cobra,
use the CMOS-version of the 555 timer circuit. You should be able to generate 1 pulse every three hours (better use a timer circuit and a binary counter, e.g. CD 4020 to keep the timing capacitor within small dimensions and timing more accurate).
Use a JK-Flip-Flop (CD4027) to switch on the loads alternating.
Boncuk
hi guys, thanks for the input, i have just looked at a couple of circuits that use the ICs you mentioned, they all use a relay for switching between side A and B.
this will consume too much of my power holding the relay coil for 3 hour periods.
ideally the 2 outputs from these ics should light leds, not a relay that toggles back and forth.
will keep looking and see what i can find
cheers again guys
