Hello again,
You keep insisting on changing this back to something that is not as good. I have so far mentioned that the resistor R30 should be higher like 100k several times now. If you change the other resistors too then you loose the advantage of being able to use a higher reference voltage. It's not just the higher impedance of the resistors, it's also the relationship of the impedances between resistors. So one needs to be 100k and the others 10k. That's about the best you'll get, and it's not all that hard to understand or to accomplish. So adjusting the reference will then be centered around 2v instead of 0.2v. If there was no advantage then we could have used 1k resistors and adjusted the reference to 0.020 volts, but that's ever worse than 0.2 volts.
But do it any way you want to if you still dont understand why we are doing this![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
