Oh, if that's what you are doing then yeah, it should work because although the differential inputs of the op-amp are not floating, the secondary of the transformer is floating so the secondary of the transformer will float to whatever the op-amp is.
It would flow how it normally does. There's nothing special there. The purpose of tying grounds together between two different circuits is to make sure they both have the same reference so they can properly communicate with each other to make sure one circuit doesn't. Everything else is the same.Thank you,
and how is ist about the current through the feedback resistor?
how does it flow back?
so there is no current flowing from secondary through the fedback resistor like in my drawing in blue?
i thought, becaue of the high input impedance of the opamp,
the current schould flow in the direction which i have drawn...
