()blivion
Active Member
I need a dirt simple basic oscilloscope to add to my tool box. I did some Google investigating and found that there are some circuits for a simple buffer that can be made for turning a PC sound card into an oscilloscope. I like this idea a lot since it's cheep (I can't afford to buy even a cheep toy scope) and it allows the possibility for me to use more advanced sound processing software like Cool Edit or similar and get some interesting incite into not just the waveform, but the spectrum as well. I am more or less aware of the limitations of using a sound card as a oscilloscope. I believe a correctly built unit will work for my modest needs.
Here is the rundown of the features I need/want.
1) Can survive RMS 240 mains continuously irrespective of user settings.
2) Is reasonably linear from 20Hz up to 30~40Khz.
3) Has switches for "range", IE... [1/100] [1/10] [1:1] [x10] [x100]
4) Ability to easily calibrate with a good DMM.
5) Does not use exotic parts. (Standard Op-Amps for example).
6) Does not load the source much, 1M ohm input impedance preferred.
7) Will work with the probes I already have. (100 Ohm - 9 Mega Ohm switch on probe)
8) Possibility to add a basic Opto-isolator in the mix. (NEC 2561 for example, as I have a few.)
9) Can measure a waveform with a DC offset on it. (ignores the offset)
10) Is a relatively compact and simple circuit. Point-to-Point constructable.
Here is the current circuit I am looking at modifying for my needs. I got this image from here.
I have no attachment to this schematic other than it's simplicity.
Constructive thoughts are very welcome. Naysaying... not as much.
Thanks for your time.
-()blivion
*TEMPORARY EDIT*
Hear is another thought, off topic but maybe deserving of it's own thread.
I have two high speed dual 6bit ADC's I salvaged out of some satellite TV boxes. Part numbers AD9066JR and STV0190. They may make a decent high speed DSO with the right design. Datasheet says up to 60 MSPS for the AD9066JR and 40 MSPS for the STV0190. If this sounds like an interesting project I could make a new thread? Or maybe a newer and better ADC could be found on one of the usual retailer sites. Either way, *I* need a scope for CHEEP. And this could possibly work for me.
-()blivion
*TEMPORARY EDIT*
