()blivion
Active Member
So... I prototyped up the circuit, I used a RC4558P for the Op-Amp instead of the other one I had picked out. It supposedly has a bit more bandwidth. At first I was having some really odd results. I was getting the output slammed to the rail even though both inputs were approximately the same voltage. Thought for sure the OP-Amp was fried. So I swapped out for an new one and same thing??? Was scratching my head wondering what was going on. Turns out I needed to be more careful at taking measurements. I measured the same spot twice apparently. The - and + inputs were NOT at all the same, I had the wires hooked into a different point on the clamping diodes than I should have. Wasted 2 hours tracking that down and finally finding the problem and fixing it. SSDD I guess.
After I got that to work and got the output off the rail, I noticed that there is quite a lot of DC offset on it. Did some checking, just input biasing I think. Need to design a way to fix this maybe. Haven't done anything yet but I know it's there.
So then, everything checked out electronically, no smoke. So it's ready to test... But I don't want to use my more expensive PC for the first test run. So I fire up the old spare P4... and... no thumb drive. Search for that a while, knowing that I could prolly transfer the scope software with the network if I bother to set it up again. Figured finding the thumb drive would be faster, WRONG. It's at a friends house I remember after having searched for it for 3 hours. Decide that I avoided using the network so hard that I might as well keep it up and hobbled my VX10000 into service as a thumb drive. Three hours to transfer 10.3MB is still faster than dialup I guess...
Anyway, enough ranting. I got the software on the PC, configured the sound card, got it installed, powered the breadboard, hooked up the probes, plugged in the output from the board to the line in on the sound card, and.... It worked!!! Here is the picture of the scope program in action.
Note that one probe was touching the metal anti reflection coating of a CRT monitor, and the other was touching... me. I guess I work well as an antenna for 60Hz. Interestingly, the one waveform shows 120Hz. I'm fairly certain the monitor is NOT refreshing at that speed. I rather expect it is some kind of natural harmonic frequency doubling of 60Hz power. The waveforms is not exactly sine either. Looks to have some harmonics of some kind in there. Need a real signal source to figure it all out. guna do that next.
Here is also a picture of the setup all prototyped together and such. After I play around and make sure it all works well, I'll move to a point to point board and metal case.
