Oshonsoft LCD Setup
OOPs, sorry, I don't know how to get Oshon code.
This is the Oshonsoft Forum..:)
What did you use to run that image of the LCD that you posted.?
I've loaded the Hex. file into the program and set the LCD as per your suggestions and press F1 to run and get the image.
I've got the attached Hex. file but don't know is it what you ask or not.
OK, I will use that hex file for a OSH test.:)
Do you know how to use Oshonsoft Basic.?
hi aljamri,
I see whats happening in Oshonsoft.
When running in simulation, the program is much slower, so any program delays take a very long time.
The program may appear to have stopped but its running in the delays loops, very slowly.
Can you write in Oshonsoft Basic.???
EDIT:
If you are using the code you posted, for a test delete the delay 2000ms
No, I'm loading Oshonsoft with Hex. files compiled either from MikroC or MPASM, but dont know that it has its own compiler or not!
I'm aware about this, for that I'm decreasing the clock Freq. into 1MHz and increasing the rate upto Extremly fast or Ultimate.
As usual You are right, when I deleted it, the program works fine and updating, but is this going to work in real circuit as well as on OshonSoft ?
**broken link removed** Originally Posted by ericgibbs **broken link removed**
Decreasing the Sim clock rate to 1MHz will make it 4 times SLOWER!
Leave out the long delay while you are using the OSH simulator, put it back in when getting ready to program a PIC.
Can you tell me exactly what you are trying to do.?
You have a mixture of 'C' , ASM and some Basic ie; 'Save Settings'
Using OSH basic this is all you need to show the adc on the LCD.
[CODE
Define CONF_WORD = 0x3f31
Define SIMULATION_WAITMS_VALUE = 1
AllDigital
Define LCD_LINES = 2
Define LCD_CHARS = 16
Define LCD_BITS = 4
Define LCD_DREG = PORTB
Define LCD_DBIT = 0
Define LCD_RSREG = PORTB
Define LCD_RSBIT = 4
Define LCD_EREG = PORTB
Define LCD_EBIT = 7
Define LCD_RWREG = PORTB
Define LCD_RWBIT = 6
Define LCD_READ_BUSY_FLAG = 1
Dim num As Word
ADCON0 = 0b11000000
ADCON1 = 0b10001111
TRISA = 0xff
TRISB = 0
Lcdinit
loop:
Lcdcmdout LcdLine1Home
Adcin 0, num
Lcdout #num, " "
Goto loop[/CODE]
  • aljamri1.bas
    aljamri1.bas
I put the clock speed back to 20MHz and got faster simulation :).
I'm trying to measure 1 to 5 volts as what I told you in https://www.electro-tech-online.com/threads/reading-4-20-ma-on-lcd-using-pic16f876a.119563/ ", and since I found Oshonsoft much easier than programming and testing real chip, I start testing here.
I dont know, as I told you, I used the hex file generated from Mikroc or MPASM and running the oshonsoft, as simple as this.
