Hi everyone !
This sounds bad but I need it
I want to buid a circuit that will produce enough voltage to paralise or kill a circuit (stop it from woking), if possible without opening the case.
just want to do it.
Use a taser or stun gun.
A taser works on you doesn't it? And you are far more immune to EMP and ESD than a circuit is.
to be good in any thing u need to kow the good the bad and the ugly.
no suggestions ?
By the way, dumb question perhaps but what is ESD an acronym for? Electro-static discharge perhaps?
That's for me to know and for you to find out![]()
I'll go with electro-static discharge. I'm certainly more protected against static than most circuitsbut you see what I meant, right? Tasing a circuit may well trash it, but it's not going to be much help inside an insulative case. Need a powerful electrical field to induce a current in the circuit for that, i.e. an EMP generator. Not going to happen using a taser
not sure of the calculations involved, been a while since I did physics involving induction due to electromagnets (and I did it at a basic level even then) but I'm thinking power is required, not just voltage.
A large enough EMP might stop the 419 scammers. Perhaps it is a worthwhile project.![]()
dknguyen said:EMP has similar problem when in a metal case
This sort of topic should be against the forum rules or we should at least be able to flame the original poster to some extent.![]()
