Parallel Port Relay
sammy004
Hi guy I just wanted to know if I want to build this project will it be possible to get a circuit design online I looked everywhere but I came here for my last resort. Oh here is the project.
any help will be greatly appreciated.
Hi sammy004,
here is an 8-channel output "plug & play" circuit, containing the necessary power supply on board.
Just plug it into mains and connect to the parallel port of your PC.
The input circuit uses buffers to protect the port chip from possible damage.
You might use Eric Gibbs' parallel-port-timer software to control outputs timed or manually.
The PCB layout is single sided with three wire jumps. Board size is 144.15X100.33mm (5.6750X3.95").
If you are interested in the files please PM me your full name and email address.
If your mains voltage differs from my design also inform me about it. The circuit can be wired for mains voltages of 110(120) and 220(230)VAC. I'll apply the necessary changes directly to the PCB layout.
Boncuk
