Path-Remebering Bot..
                movlw   B'00000001'
                movwf   T1CON;		enable timer 1
                movlw   low(d'50000')
                movwf   CCPR1L
                movlw   high(d'50000')
                movwf   CCPR1H
                movlw   B'00001011';	enable special event trigger on CCP1
                movwf   CCP1CON;
Sorry, I copied the code from a project that used the timer 1 oscillator.
Change the top line to be as shown above.
I've also made it clearer that the 50000 is decimal.
Pommie said:
                movlw   B'00000001'
                movlw   low(d'50000')
                movwf   CCPR1L
                movwf   CCPR1H
                movwf   CCP1CON;
I had noticed that the first time itself ... and I had made the corrections as above.. but it is still not working.. the CCP1F flag is not setting 'HIGH' when the comparison occurs. (i chkd this on the simulr) Please help..
I just put the following in MPLAB and it works fine.
                LIST        P=16F73
                #include 	"p16f73.inc"
                org	0
                movlw   B'00000001'
                movlw   low(d'10000')
                movwf   CCPR1L
                movlw   high(d'10000')
                movwf   CCPR1H
                movwf   CCP1CON;
WaitTimeUp      btfss   PIR1,CCP1IF
                goto    WaitTimeUp
                bcf     PIR1,CCP1IF
                goto	WaitTimeUp ;   <<<<<< Put Break point here
	end
If you put a break point where I have indicated then it should stop every 10mS = 1/100 th of a second.
                LIST        P=16F73
                org	0
                movlw   B'00000001'
                movlw   low(d'10000')
                movwf   CCPR1L
                movwf   CCPR1H
                movwf   CCP1CON;
                goto    WaitTimeUp
                bcf     PIR1,CCP1IF
	end
Hi Mike..
There seems to be somwrhing wrong with the simulator... I'm using Oshon Pic Simulr.. ver 5.33. The code is infinitely looping around
                goto    WaitTimeUp
I'm stepping the simuln run.. and the Flag Bit is not setting HIGH at all :(
I'll burn the code.. and program it to flash an LED after setting of the flag bit.. things will be clear then... will let you know..
