My place use type F electric plug, but the grounding is not working at all. Years ago, while I still running digital printing business, I use about 10 meters stainless steel rod to the ground(earth) and the wire direct to the type F electric plug ground connection. Everything is okay.
Now I move to the 2nd floor and the grounding is not working, because the ground connection is not connected with the 1st floor grounding. Since there's only lamp and small electronics on the 1st floor, I move the grounding wire to the 2nd floor and the wire direct to the type F electric plug ground connection. When I touch PC casing, there's no static electricity, so it's working. But when I want to go out, I heard a sound from the main electric terminal box on the 1st floor, like a high voltage pulse sound. But I see nothing and everything looks fine. Than I remove the ground wire, the sound is disappear. Than I connecting the grounding wire direct to my PC case. The sound from the main electric terminal box is back. To avoid undesirable things, I stop using the grounding wire.
My question, how to ground my PC?
