PCB and schematics
dark666
Hi to all.
Can some one indicate me a website or maybe some book name where can I find the several PCB and schematics component codes?
Eg. in a schematics or PCB
Q - Transistor
R - Resistor
C - Capacitor
X - Crystal
F - Fuse
etc, etc
And can anyone tell me what is a component soldered and marked with a FS?
Thanks to all
Thats not what I want. I want the codes that are written in the PCB or the schematics next to the soldering.
EG. A transistors is soldered and arround the component there a line that says Q100 that means its the transistor number 100 in the circuit. Same goes for R for resistor, D for diode and U for IC and I came across a component marked as FS500 wich means that its the FS number 500. What is an FS? I'm looking for those codes.
Hi to all.
Q - Transistor
R - Resistor
C - Capacitor
X - Crystal
F - Fuse
etc, etc
Thanks to all
You please post the part of the schematic that contained the abbreviation "FS" . It would help some one to offer a constructive comment.
Whether it is "LS" to indicated Loud speaker??
Please see whether thr Hobid link helps
OEM Electronic Component IC Inventory, Military Aircraft Aerospace Marine Automotive Parts
Generally speaking it is dependent on the manufacturer. You are looking for what is called "reference designators" such as the examples you posted. I found the attached file pretty easy from a google search.
  • Reference%20Designators.pdf
