lord loh.
I am trying to design a PCB using the Laser printer/Iron/FeCl3 process...
I managed to print a board with 0.25mm track width on a PCB. However parts of the tracks were faded and lost...due to inefficient ironing. (my fault) However most of it was clear and well imprinted.
I retouched the faded parts with a marker and corroded it and ended up with a few broken tracks. (circled red in picture)
I would like to know what is the thinnest track that can be achieved by the laser printer/Iron/FeCl3 process ?
Also when I checked the continuity of the good tracks using the diode tester range of the multimeter, i got figures like 325, 215 ...(mV of voltage drop between two points on the track)
Couldn't this high resistance of tracks be a serious problem?
Pleas give me a few tips and suggestions for my next PCB... Should I go for a 0.30mm / 0.40 mm ?
I am using a software called diptrace (https://www.diptrace.com/)
Thanks in advance.
Added later :
What is the mm to mil conversion? and what does mil stand for?
Thanks again.
Thanks in advance.
Added later :
Thanks again.
