alandaniel132
During the manufacturing of 10,000 units, there are 10% defects.
As an electronics test engineer, what can I do to solve this issue?
What is the meaning of ""edn tales from the cube"?Seems to me (and I should think anyone qualified to be in that position), the first step is to investigate how the "units" are failing.
Are the pcbs failing? Open or shorted tracks?
[How could you tell? If the board itself is the problem, why and how do you remedy the problem?]
Is there an assembly issue?
[Same question as above.]
Is there a component issue?
[Defective, counterfeit, use of different parts than specified?]
Is there a flaw in the circuit design?
Is there a board layout issue?
After that, the possible causes are endless.....
I suggest searching for "edn tales from the cube" and reading every one of them to gain a tiny bit of understanding about what you've asked.
Thank you.The first thing would be to make some kind of a table which lists the defects.
Until you know what the defects are, there is no way to find a solution.
Typical problems could be:
Poor design
Incorrect assembly
Faulty components from the suppliers
Faults caused by poor testing techniques or faulty test equipment.
I did search for "edn tales from the cube"Perhaps you don't have the proper mindset for the position you seek. If you ask "what's that?" rather than having the initiative to to take a look for yourself ("I suggest searching for "edn tales from the cube" and reading every one of them,"), you're not going to do much good trying to solve problems.
What are Tales From The Cube about? What are you being asked to do? If you don't see the relationship, the job is not right for you.
I would presume all his threads are homework questions, that's he's too lazy to do himselfIs this a school question or are you really getting 10% defects? If I had 1% defects, I would be very unhappy.
the 1% defect is just an assumption.Is this a school question or are you really getting 10% defects? If I had 1% defects, I would be very unhappy.
If you are referring to PCB fabrication defects, then...During the manufacturing of 10,000 units, there are 10% defects.
Thank you and very infomative.If you are referring to PCB fabrication defects, then...
Establish an "acceptable quality level" (AQL) to be used by your PCB receiving Inspection department. Then hold the PCB fabrication company accountable to it. The AQL is usually established by your company through collaboration between production manufacturing, quality control, and engineering. Once an AQL is established, it must be agreed to by the PCB Supplier to enable them to be a "supplier". In my day our AQL was 1%.
That's why this had an eerie familiarity. It was sort of like a Deja Vue when I read it. Normally focused on QC issues. Thank you Nigel.I would presume all his threads are homework questions, that's he's too lazy to do himself![]()
