diecast lighting
The black piece on the front is labaled LOTB.
The pic on the back is 16f688
Why not just buy the device in the photo?
A sample is designed so you can order more, who made the sample?
I'd design using 74hc595, no transistors/resistors,
and without the PIC, and including a short explanation of the serial interface.
in the long run it's less expensive than hardware.so why have an extra charlieplex code set
for larger number of LEDs, you'd have to use driver IC anyway, if you want some level of brightness.
and for a 7-seg LED, you can not use charlieplex anyway.
incidentially, in our country, we have 3 metre high LED sign boards, made from 5mm LEDs, and 100s of standard DIL 74hc595.
