I have just started to use this program (free version) to draw schematics.
Maybe somebody here with more experience knows the fix to the problem I encountered:
When placing a part from the library (Op Amp - for example) and then rotating it for correct orientation, the part number gets rotated also but the pin numbers do not.
So, with 180 deg. rotation, I end up with upside down pin numbers.
Is there a way to delete the pin numbers from the library parts? Or any other clever fix to get around this shortcoming?
Thanks for reading this,
Klaus
Klaus
