Hello All
I have surfed in from the WWW to ask a question.... I have perused some past posts and know there must be somebody here who can answer my question.....
I will readily admit I'm a dope at electronics - I have enough sense to do some basics etc...But I'm a dope...... (smart enought to ask others I guess )
Anyway.....
I have a slot car track..... And - I'm trying to make two "slot type" photomicrosensors work with a Phidget I/O board (that go into the PC - that ties in with my slot racing software...)...... The two sensors are about 18 inches apart.... Same lane (for those familier with slot tracks) - or to explain - the same car passes both sensors - seperated by 18".... The senors are Omron EE-SX1070.... Very basic. It works great when you are cruising - no issues at all - however.....
The documentation says they rise and fall at 4 miliseconds...... So - my problem is - the darn car covers the 18 inches in less than a tenth (when racing).... Sounds like it should come close to working - right? Of course not......Basically the input is only seeing one signal. I'm not able to get two distinct signals.....
My question is - how can I "pulse" the signal faster - or in my terminology - have it die quicker
The "output" from the sensor goes right into the I/O card - I don't have anything branching off like an LED..... I'm not sure If a zenor Diode will do it - It just seems to stay hot too long....maybe an LED to help pull the voltage down quicker..... or both??
I appreciate any input!!
Matt
Anyway.....
Matt
