mramos1 said:WOW.. That is cool.. So they set high on one termistor, ground junction, and count. Then go high on POT, ground junction and count? Subtracting thermistor from POT and that is the value?
I am lost on it, I see the logic with the two to compensate the for battery getting lower, just not the sequence to do it.
Check the source, it's on the EPE site and is called 'Freezer', it's in the PIC source code listing.
Essentially though you make the resistor you're NOT using an input, make the other an output and low, and wait to make sure the cap is discharged - then simply take the pin high and count until the input goes high as well. Do the same with the second output pin, and you have two readings you can compare, you even have an adjustable pot you can alter with a screwdriver!.
It's so delightfuly simple!.
My mod, which they published, was simply to connect the sounder across two I/O pins and drive it bridged, LOT'S louder, with no extra components! - don't you just love a mod like that?.
