PIC - Polyphonic sound
VictorPS
Is it possible to play polyphonic sound with 16F628 or even 16F630 (no H/W PWM)?
I have try PICSound by Roman Black, but it require external eeprom.
I like to generate "Jingle bell" sound, how to generate it using PWM?
Sorry, I've not done a sound tutorial!.
The Roman Black example actually plays back a stored recording, Jingle Bells is far simpler than that, you could just generate the tones - there are various examples on the net for this.
If you want to play back a recording, you might look at , which shows how to use a large table in the PIC memory and play it back.
Thanks for reply. :)
Actually the sound that I like to generate as attached WAV or something close to it.
Rather than plain tone by square ware only, which is bore very soon.
I believe it can be done, or how the chime clock generate "dong...dong...donggggg..."
Using MIDI , wavetable (like in PC soundcard) , is it too tough for PIC ?
Or, can someone tell me, bell sound are combination of what waveform & frequency?
Thank you...
  • bell-up.zip
Considering that file is 164KB, where in an 8K PIC were you hoping to fit it?. The PICList link I posted previously shows how to play back a sound sample from program memory (as a large table), but it's obviously limited by the amount of memory available.
options?
If the (any) sound sample were stored in a scabby old EPROM or something (assuming dead simple 8 bit raw data) then it could be simply read back to a D-A using a binary counter to generate the addresses.
This does assume the data can be converted to or recorded as something suitable?
Or am I starting to get too close to the sound record/playback chips that are available?
