Mosaic
Hi all:
I've decided to make my own proto/breakout board that plugs into a breadboard for prototyping pics from 6 pin thru 40 pin DIPs
I figure that a crystal isn't that necessary anymore as most modern pics have flexible units built in which permits s'ware controlled clocking.
I expect to provide both 5V and 3.3V as well as a 0.1% precision Vref (adjustable), a 4 digit 7 segment display and a few buttons & LEDS and a beeper.
All 40 pins (via a bottom hdr) will connect to the breadboard and a matching top mounted hdr will connect to my Rigol Logic scope for debugging.
The board will permit up to 3 independent pics (totaling <40 pins) to be operating simultaneously. Optionally Opamps can be used side by side with smaller than 40pin PICS.
The board will have inbuilt jumpering for all pins to permit reordering the way the pins come out to the headers for simpler breadboarding.
A jumpered ICSP header is present as well.
I am hoping for any comments b4 I commit to build.
Most proto boards I have seen cater for crystals (I've never had to use one) and just a few PIC sizes, with only one in action at a time.
If it goes well I can post it as a project here on ETO.
thx.
thx.
