PIC Simulator
hi eric
can you tell me what is the difference between SOFT UART and HARDWARE UART ?
The hardware UART is a logic block that exists in the PIC and it controls all the bit timing to create RS232 signals.
A software only exists in the program, you have to create the bit timing etc within the program in order to meet the RS232 specification for the signals.
hi
i just uploaded new program
just a simple program that mixed i from code to code :)
i dont know what to explain , maybe i will be just post the code
so you can have a try :)
  • LCD On - Off.bas
    LCD On - Off.bas
It works fine for me, whats supposed to be wrong.?
Did you have this line Define SIMULATION_WAITMS_VALUE = 1 just under AllDigital.???
ok , i add it to the code :)
hi TT,
Try my version.
AllDigital
Define LCD_BITS = 8
Define LCD_DREG = PORTB
Define LCD_DBIT = 0
Define LCD_RSREG = PORTA
Define LCD_RSBIT = 1
Define LCD_EREG = PORTA
Define LCD_EBIT = 3
Define LCD_RWREG = PORTA
Define LCD_RWBIT = 2
Lcdinit
TRISA = 1
TRISC = 0
Lcdout "PORTA.0 = "
loop:
Lcdcmdout LcdLine1Pos(11)
If PORTA.0 = 1 Then
Lcdout "ON "
PORTC.4 = 1
PORTC.5 = 0
Else
Lcdout "OFF"
PORTC.5 = 1
PORTC.4 = 0
Endif
WaitMs 1000
Goto loop
hi TT,
Try my version.
AllDigital
Define LCD_BITS = 8
Define LCD_DBIT = 0
Define LCD_EBIT = 3
Lcdinit
TRISA = 1
TRISC = 0
Lcdout "PORTA.0 = "
loop:
If PORTA.0 = 1 Then
Lcdout "ON "
PORTC.4 = 1
PORTC.5 = 0
Else
Lcdout "OFF"
PORTC.5 = 1
PORTC.4 = 0
Endif
WaitMs 1000
Goto loop
its work ok too :)
Thanks! Found it, Should help immensely helpful in a project I am playing with.What I'm trying to do is write user defineable graphics (8 at a time) to the screen, update the UDG's and reprint them to a different area fo the screen etc. creating a (sort of) dot addressable display on a alphanumeric screen.I understand the limitations I will run up against not least the gaps between characters, but it fascinates me to see how far this can be taken.I have managed to get 32 different chars on a 2x16 display so it is possible.
Ultimately I would like to write an Interupt driven 'Blitter' to dot scroll some sort of large graphic.Proberably not very practical but appeals to my hardware hacker nature.
i have LCD ( 16x2 ), some LEDs , some NPN transistor , LDR , Motor , and four servo , 2 7 segment display and Pickit 2 ( for UART communication )
what do you suggest ? :)
hi eric
how can i make analog input become two ?
like " value PORTA.0 = 500 "
....." value PORTA.1 = 200 "
Look at this.
'16F886 and 16F88
AllDigital
Define LCD_BITS = 4
'Define LCD_DBIT = 8
Define LCD_RSREG = PORTB
Define LCD_RSBIT = 3
Define LCD_EREG = PORTB
Define LCD_EBIT = 2
Define LCD_RWREG = PORTB
Define LCD_RWBIT = 1
Dim adcv0 As Word
Dim adcv1 As Word
TRISA = 3  'RA0 (AN0) is input
TRISB = 0  'PORTB is output
ANSEL = 0x03
'Initialize the A/D converter
ADCON1 = %00000011  'Make AN0 analog inputs,
'make reference voltage = VDD
ADCON0 = %11000101  'A/D clock is internal RC, select AN0
Lcdinit
loop:
Lcdcmdout LcdLine1Home
Adcin 0, adcv0
Lcdout "adc0 test=", #adcv0, "  "
Adcin 1, adcv1
Lcdcmdout LcdLine2Home
Lcdout "adc1 test=", #adcv1, "  "
Goto loop
End
Look at this.
'16F886 and 16F88
AllDigital
Define LCD_BITS = 4
Define LCD_EBIT = 2
Dim adcv0 As Word
Dim adcv1 As Word
ANSEL = 0x03
Lcdinit
loop:
Adcin 0, adcv0
Adcin 1, adcv1
Goto loop
End
thanks
it work
i will show my new code after i finished it :)
hi
i do a little research
i think i only need to change the code to this :)
[COLOR="red"]ANSEL = 0x07  'make RA0, RA1 and RA2 Analog Input[/COLOR]
ADCON1 = 0
hi
i have just finished my new code :)
ALREADY TESTED IN REAL WORLD
it can count up to 1000 rather than 255 , right ? :)
i will upload the video later :)
I will give your softuart2.bas a run in Oshonsoft
Define SEROUT_DELAYUS = 500
Dim i As Word  'to declare i as word not byte because Byte is just only around 256
i = 1000  'make i to 1000
WaitMs 1000  '1000 ms delay
For i = 1 To 1000 Step 1  'from 1 to 1000 , +1 every Step
Serout PORTB.7, 9600, "Number: ", #i, CrLf  'set and use portb.7 to send data and set baud rate to 9600
WaitMs 500  'delay 500 ms
Next i  'step again
[COLOR=Blue]
'this section of the code is incomplete.??[/COLOR]
loop:
Serin PORTB.6, 9600, i  'things that will be displayed at uart window
