Hi, I have revisited a simple ADC project using 12f675. I've set GPIO,0 as analogue in, & GPIO,1 & 2 as outputs connected to two led's used to indicate input level < or> depending on value set in ADC reading (e.g. 2volts) I set a DC value between 0v (Vss & 5v = Vdd) using a 10k pott. ADC set up for ext ref 5v vdd. The circuit works_accept as I advance the pott in either direction the led's alternatively switch on and off as the voltage increases or decreases at several intervals. The adc voltage value = 102 (2 volts) for 8 bit convertion. One led should be lit only when > 2v & the other lit < 2v. I'm using the pott only to prove my circuit, and eventually use either a temp sensor (resistive) or an LDR device with one of the GPIO's to switch a relay.
This is the first time I've used this PIC and come accross this problem.
I have included the asm listing. Note very new to programming_most gratefull again for any assistance.
; Filename: xxx.asm *
; Date: *
; File Version: *
; Author: *
; Files required: *
; 12F675.lkr *
; Notes: *
list p=12f675 ; list directive to define processor
#include <p12f675.inc> ; processor specific variable definitions
errorlevel -302 ; suppress message 302 from list file
__CONFIG _CP_OFF & _CPD_OFF & _BODEN_OFF & _MCLRE_ON & _WDT_OFF & _PWRTE_ON & _INTRC_OSC_NOCLKOUT
; '__CONFIG' directive is used to embed configuration word within .asm file.
; The lables following the directive are located in the respective .inc file.
; See data sheet for additional information on configuration word settings.
;***** VARIABLE DEFINITIONS (examples)
; example of using Shared Uninitialized Data Section
INT_VAR UDATA_SHR 0x20
w_temp RES 1 ; variable used for context saving
status_temp RES 1 ; variable used for context saving
RESET_VECTOR CODE 0x000 ; processor reset vector
goto main ; go to beginning of program
INT_VECTOR CODE 0x004 ; interrupt vector location
movwf w_temp ; save off current W register contents
movf STATUS,w ; move status register into W register
movwf status_temp ; save off contents of STATUS register
; isr code can go here or be located as a call subroutine elsewhere
movf status_temp,w ; retrieve copy of STATUS register
movwf STATUS ; restore pre-isr STATUS register contents
swapf w_temp,f
swapf w_temp,w ; restore pre-isr W register contents
retfie ; return from interrupt
; these first 4 instructions are not required if the internal oscillator is not used
call 0x3FF ; retrieve factory calibration value
bsf STATUS,RP0 ; set file register bank to 1
movwf OSCCAL ; update register with factory cal value
; set file register bank to 0
; ======================= DELAY =================================
DELAY1
CLRF TMR0 ; START TMR0
LOOPBB MOVF TMR0,W ; READ TMR0 INTO W
SUBLW .200 ; TIME -W
BTFSS STATUS,Z ; CHECK TIME W = 0
GOTO LOOPBB
RETLW 0 ; RETURN AFTER TMR0 = 100
main
bsf STATUS,RP0 ; select bank 0
movlw .9 ;B'00001001' ; SET BIT 0 as input ;
movwf TRISIO
movlw B'00000111'
movwf OPTION_REG
movlw B'00010001' ;set bit 0 as analogue input
movwf ANSEL
bcf STATUS,RP0
movlw B'00000111'
movwf CMCON
bcf STATUS,RP0
movlw B'00000001' ; left justified (bit7=0) /255
movwf ADCON0
clrf GPIO
;======================== START OF PROGRAM ============================
BEGIN
bsf ADCON0,GO
WAIT btfsc ADCON0,GO
goto WAIT
bsf STATUS,RP0
movf ADRESL,W
sublw .102 ; 8 bit ADC convertion = 255/5 x 2v = 102
; == 10 BIT ADC CONVERTION _ 2volts
btfsc STATUS,C ; 1,023 / 5volt vdd = 204.6 x voltage in
goto LED1 ; e.g_ 2volts x 204.6 = 409
goto LED2
LED1 bcf STATUS,RP0
bsf GPIO,1
bcf GPIO,2
goto BEGIN
LED2 bcf STATUS,RP0
bsf GPIO,2
bcf GPIO,1
goto BEGIN
END ]
; Date: *
; File Version: *
; Author: *
; Files required: *
; 12F675.lkr *
; Notes: *
swapf w_temp,f
DELAY1
GOTO LOOPBB
main
movwf TRISIO
movlw B'00000111'
movwf OPTION_REG
movwf ANSEL
bcf STATUS,RP0
movlw B'00000111'
movwf CMCON
bcf STATUS,RP0
movwf ADCON0
clrf GPIO
BEGIN
bsf ADCON0,GO
goto WAIT
bsf STATUS,RP0
movf ADRESL,W
goto LED2
LED1 bcf STATUS,RP0
bsf GPIO,1
bcf GPIO,2
goto BEGIN
LED2 bcf STATUS,RP0
bsf GPIO,2
bcf GPIO,1
goto BEGIN
END ]
