#if defined(__PCM__)
#include <16F877A.h>
#fuses HS,NOWDT,NOLVP
#use delay(clock=20000000)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)
#elif defined(__PCH__)
#include <18F4520.h>
#endif
#define _USE_LCD_
#define CLOCKS_PER_SECOND 1000
#include <time.h>
#include <rtctimer.c>
#include <stdlib.h>
#include <input.c>
#if defined(_USE_LCD_)
#include <lcd.c>
#endif
void InitTime(void)
struct_tm t;
//tm_year is years since 1900.
printf("\r\nYear (0-99): ");
t.tm_year = (int16)get_int() + (int16)100;
printf("\r\nMonth (1-12): ");
t.tm_mon = get_int() - 1;
printf("\r\nDay (1-31): ");
t.tm_mday = get_int() - 1;
printf("\r\nHour (0-23): ");
t.tm_hour = get_int();
printf("\r\nMinute (0-59): ");
t.tm_min = get_int();
SetTime(&t);
printf("\r\n\n");
void main(void)
char tString[32];
int i = 0;
time_t tTime = 0;
lcd_init();
#endif
printf("\r\n\nex_rtctimer\r\n\n");
InitTime();
#if getenv("CLOCK")==4000000)
setup_timer_2(T2_DIV_BY_1,250,4);
#elif getenv("CLOCK")==20000000)
setup_timer_2(T2_DIV_BY_4,250,5);
#else
#error Configure TIMER2 so it interrupts at a rate defined by CLOCKS_PER_SECOND
#endif
enable_interrupts(INT_TIMER2);
enable_interrupts(GLOBAL);
while(1)
tTime = time(NULL);
ctime(&tTime, tString);
printf("It is currently: %s\n\r", tString);
lcd_gotoxy(1,1);
i = 3;
while(tString[i] != '\0')
lcd_putc(tString[i]);
i++;
#endif
delay_ms(1000);
#include <16F88.h>
#use rs232(baud=9600, xmit=PIN_B5, rcv=PIN_B2)
#endif
#include <16F88.h>
#fuses HS,NOWDT,NOLVP,INTRC_IO
#define _USE_LCD_
#include <time.h>
#include <stdlib.h>
#include <input.c>
#include <lcd.c>
void InitTime(void)
struct_tm t;
SetTime(&t);
printf("\r\n\n");
void main(void)
char tString[32];
int i = 0;
time_t tTime = 0;
lcd_init();
InitTime();
setup_oscillator(OSC_20MHZ)
while(1)
tTime = time(NULL);
lcd_gotoxy(1,1);
i = 3;
i++;
delay_ms(1000);
#include <16F88.h>
#fuses NOWDT,NOLVP,INTRC_IO
#use delay(clock=4000000)
#define _USE_LCD_
#include <time.h>
#include <stdlib.h>
#include <input.c>
#include <lcd.c>
void InitTime(void)
struct_tm t;
SetTime(&t);
printf("\r\n\n");
void main(void)
char tString[32];
int i = 0;
time_t tTime = 0;
lcd_init();
InitTime();
getenv("CLOCK")==4000000;
getenv("CLOCK")==20000000;
Executing: "C:\Program Files\Microchip\Third Party\PICC\Ccsc.exe" +FM "Lab1.c" +DF +LN +T +A +M +Z +Y=9 +EA
*** Error 18 "Lab1.c" Line 3(10,17): File can not be opened
Not in local "H:\bit.h"
*** Error 18 "Lab1.c" Line 4(10,17): File can not be opened
Not in local "H:\I2C.h"
*** Error 128 "Lab1.c" Line 12(1,4): A #DEVICE required before this line
3 Errors, 0 Warnings.
Halting build on first failure as requested.
BUILD FAILED: Thu Apr 29 17:35:40 2010
#include "bit.h"
#include "I2C.h"
// macros / defines
#define UP 1
#define DOWN -1
typedef unsigned short Byte;
typedef unsigned short UINT8;
// File scope variables
static Byte ds1307_started = 0;
// Read the keys
unsigned short read_ANA_keys(void) {
unsigned int val;
val = Adc_Read(0);
// Decode the analogue
if (val>800 && val<860) {val=1;}
else if (val>490 && val<530) {val=2;}
else if (val>300 && val<350) {val=3;}
else if (val<300) {val=4;}
else {val=0;}
return val;
// globals for interrupt.
void init(void) {
int i,ack,c;
OSCCON = 0x70; // b6..4 = 110 = 4MHz 111=8MHz
ANSEL = 0x00; // RA0 enabled as needed in program.
// Timer 1 on
T1CON = (1<<TMR1ON);
void init_ports(void) {
PORTA = 0;
TRISA = 0x00; // 0=o/p - sets analogue pins to digital output.
// AN0 set to input as needed.
PORTB = 0;
TRISB = 0x01; // 0=o/p // Receive on RB0.
// RA5 can only be input on 16F88 so move bit 5 to 6, 6 to 7.
// ret table is for straight through
// PORT 0 1 2 3 4 5 6 7 to a b c d e f g dp
// So map to new outputs:
// 0 a, 1 b, 2 c, 3 d, 4 e, 6 f, 7 g - loosing dp
// i.e. keep 1st 5 and move bits 5,6 to 6,7
unsigned short int2seg(unsigned short digit) {
unsigned short r;
unsigned short ret[10] = { 0x3F, 0x06, 0x5B, 0x4F, 0x66,
0x6D, 0x7D, 0x07, 0x7F, 0x6F };
if (digit<0 || digit>9) {
r = 0x7f;
} else {
r =( ret[digit] & 0x1f ) | \
( (ret[digit] & 0x60)<< 1);
return r;
void write_DS1307(unsigned short address, unsigned short data) {
short i;
_I2C_Start();
_I2C_Wr(0xd0);
_I2C_Wr(address);
_I2C_Wr(data);
_I2C_Stop();
_I2C_Start();
// Get an ACK from the slave but give up after 3 goes don't hang waiting.
for(i=0;i<3;i++) {
if (_I2C_Wr(0xd0)==1) { // Check for NACK
_I2C_start();
} else break; // found ACK
_I2C_Stop();
unsigned short read_ds1307(unsigned short address) {
unsigned short data;
_I2C_Start();
_I2C_Wr(0xd0);
_I2C_Wr(address);
_I2C_Start();
_I2C_Wr(0xd1); // b0 is read
data=_I2C_Rd(0); // Read with NACK.
_I2C_stop();
return(data);
void start_ds1307() {
Byte sec;
if (ds1307_started) return;
sec = read_ds1307(0) & ~0x80; // CH = 0 - start.
write_DS1307(0,sec);
ds1307_started = 1;
void stop_ds1307() {
Byte sec;
sec = read_ds1307(0) | 0x80; // CH = 1 - stop.
ds1307_started = 0;
// Register update only happens if year data is not present.
// Have to change this next centuary!
void init_ds1307(void) {
// Check if initialisation is needed by checking a ram location
// use the year value : RAM location 3F is used to hold the year data
if (read_ds1307(0x3f)==0x20) {return;} // initialised so return
start_ds1307(); // Start the oscillator
// Set to 24H mode
write_ds1307(2,read_ds1307(2) & ~(1<<6) ); // reset bit 6 for 24 hour mode.
// Set the time
write_ds1307(0,0x59 & 0x7F); // bit 7 - oscailltor halt (if=1). : secs 0-59
write_ds1307(1,0x59); // : mins 0-59
write_ds1307(2,0x24 & ~(1<<6) ); // reset bit 6 for 24 hour mode.:0-23,1-12 hour
write_ds1307(3,0x07); // week day day 0-7 : day 1-7
write_ds1307(4,0x31); // (exceptions Feb,Apr,Jun,Sep,Nov 1-30) : date 1-31
write_ds1307(5,0x12); // : month 1-12
write_ds1307(6,0x99); // : year 0-99
// Write high digit of year into RAM easier code
// and gives initialisation check.
write_ds1307(0x3f,0x20); // : year 20
// Edit the DS1307 at address Addr
// add or subtract dir e.g. -1, +1, -10, +10.
// Stores the special case bits for
// CH and 12/24hour
// restoring them at the end.
void edit_DS1307(Byte Addr, Byte dir) {
UINT8 store=0;
UINT8 lim,low_lim;
int data=0;
data = read_ds1307(Addr); // Get the data.
switch (Addr) { // Control special case bits
case 0 : store = data & 0x80; data &=0x7f; break; // CH Clock Halt.
case 2 : store = data &(1<<6); data &=0x3f; break; // 12/24 Hour
data = Bcd2Dec(data); // Convert
// Limits
low_lim=0;
switch (Addr) {
case 0 :
case 1 : lim=59; break;
case 2 : lim=23; break;
case 3 : lim=7; low_lim=1; break;
case 4 : lim=31; low_lim=1; break;
case 5 : lim=12; low_lim=1; break;
case 6 : lim=99; break;
data += dir;
// Process limits
if (data<low_lim) data=lim;
if (data>lim) data=low_lim;
// finish up and restore ctrl bits
write_DS1307( Addr, Dec2Bcd(data) | store );
// clock_display
// Arguments
// bcd1 - displayed on left of segment (2 digits)
// bcd2 - displayed on right of segment (2 digits)
// blankLR -1 for no digit, 0-left, 1-right // selectively blank digits
// Each call to this routine displays a single digit
// this lets the caller do more work
// as delays between calls to this routine
// are controled from the caller.
// blankLRidx =
void clock_display(UINT8 ad1, UINT8 ad2, Byte blankLRidx) {
static UINT8 digit=0;
UINT8 pin, bcd;
char op[4];
int num;
if (++digit==5) {digit=1;}
if (digit<=2) { // Get the data
bcd = read_ds1307(ad1); // hours only appear in left digit set.
if (ad1==2) bcd &= ~(1<<6);
ByteToStr(Bcd2Dec(bcd),op); // Left
} else {
bcd = read_ds1307(ad2);
if (ad2==0) bcd &=0x7f; // seconds only appear in right digit set.
ByteToStr(Bcd2Dec(bcd),op); // Right
switch (digit) { // Choose the segment drives and display digit.
case 1 : pin=5; num=op[1]; break;
case 2 : pin=2; num=op[2]; break;
case 3 : pin=6; num=op[1]; break;
case 4 : pin=7; num=op[2]; break;
num = num - '0'; // convert to number
if ( (digit<=2 && blankLRidx==0) ||
(digit>=3 && blankLRidx==1)) {
PORTA=0; // Blank
} else {
PORTA=int2seg(num); // No blank
setBit(PORTB,pin);
delay_ms(1);
resBit(PORTB,pin);
PORTA=0;
PORTB=0;
} // clock display
void main() {
unsigned short mode=0; // Current display mode.
short edit=-1; // Change digit index or -1 - normal clock mode.
unsigned short key=0; // Current key press.
unsigned short last_key=0; // Detect key press changes.
unsigned short idx[2]; // Easier readability for code = DS1307 addresses.
unsigned short flash=0; // Control to flash a selected digit.
unsigned short blankIdx=0; // Flash digit control.
unsigned short hrs; // Temporary store.
init_ports();
init();
_I2C_Init(100000);
init_ds1307();
while(1) {
TRISB = (1<<1) | (1<<4); // Ensure SDA and SLC are inputs
TRISA = 0x01; // AN0 input to read the keys
ANSEL = 0x01; // Activate analogue input AN0
delay_us(100);
key = read_ANA_keys();
TRISA &= ~0x01; // AN0 input set as o/p to control the 7segment display.
ANSEL = 0x00; // Digital I/O
if (key!=last_key) {
switch (key) {
case 1 : // MODE i.e. select data to show on 7seg.
mode++;
if (mode>3) {mode=0;}
edit=-1;
// Changing mode so start the clock - only does it if stopped
start_ds1307();
break;
case 2 : // Select left or right digits to change
// -1 - no digits selected, 0- left 1- right
if (++edit>1) { // Finished editing - index is > 1
edit=-1;
start_ds1307(); // Leaving edit mode so start the clock
} else if (mode==0 && edit!=-1) {
// clock halt if editing seconds i.e. edit active in mode 0
stop_ds1307();
break;
case 3 : // UP
if (edit!=-1) edit_DS1307(idx[edit],UP);
break;
case 4 : // DOWN
if (edit!=-1) edit_DS1307(idx[edit],DOWN);
break;
last_key = key; // react only to key changes
} // key changed.
// Select data to display.
switch (mode) {
case 0 : idx[0] = 1; idx[1] = 0; break; // Minutes, Secs.
case 1 : idx[0] = 2; idx[1] = 1; break; // Hours, Minutes.
case 2 : idx[0] = 4; idx[1] = 5; break; // Date, Month.
case 3 : idx[0] = 0x3f; idx[1] = 6; break; // YEAR 8-ram address.
if (++flash>60) flash=0; // Cycle flash value.
// Do the displaying / flash a digit if edit !=0
if (flash>30)
blankIdx = edit; // select digit to blank.
else
blankIdx = -1; // no digit is blanked.
clock_display(idx[0],idx[1], blankIdx);
} // while(1)
