PIC18 to PIC16 asm instructions
augustinetez
Most Helpful Member
I know there used to b a 16F to 18F migration document on the Microchip website at one stage, but I'm buggered if I can find anything on that site anymore.
So quick (dumb-ish) question - is RRCF in 18F asm the same as RRF in 16F asm?
Reading the datasheets seems to indicate it is, just want to make sure I'm not missing something.
As for why do I want to know - converting this to use in a 12F chip:-
16-bit random generator (tested)
The 0xA1 is part of a prime polynom value 0xA1A1 which generates a full LFSR
Random:
    BCF     STATUS,C
    RRCF    LFSRVALUEH,F
    RRCF    LFSRVALUEL,F
    BTFSS   STATUS,C
    RETURN
    MOVLW   0xA1
    XORWF   LFSRVALUEH
    XORWF   LFSRVALUEL
    RETURN
It's not a dumb question, they are the same.
I think that the name RRCF, Rotate Right f through Carry, is to distinguish it from RRNCF, Rotate Right f (No Carry).
RRNCF has no equivalent in 16F asm, so there the RRF just means Rotate Right f through Carry.
RRNCF would be incorrect in your code as the carry bits wouldn't do anything and the code would always return with the carry bit clear.
You can mimic RRNCF in pic16 by doing,
RRF file,w
RRF file,f
first instruction moves bit 0 into carry and the second moves the file content and moves bit 0 into bit 7.
Not relevant to this question but may be useful down the line.
