Divya Sunil
I am using Multi PIC JDM programmer version 5.2 and PICprog4u for programming my PIC 16F628A. I had been using this for quite some time and it had been working alright. Now suddenly a problem has cropped up. Now when I open PICprog4u and select JDM programmer it is telling the message “Couldn’t open COM port” and after cliking OK from some 6 to 7 times it was detecting the programmer with the message “JDM programmer was found on COM1”. There after the programmer works alright. Picprog4U version I am using is 0.8.2
When I checked up the hardware tab of the PICprog4u programming window COM ports 1, 3,4,5,6,7,8,9 were ticked.
On checking up the COM ports of my PC from the device manager window, I found that the same ports were present and additionally COM ports 10,11,12,13 were also present. I disabled the COM ports 3,4,5,6,7,8,9 and tried programming and now my programmer works alright. Now in the first instance itself I get the “JDM programmer was found on COM1” message.
Can somebody help me to understand this:
- Why only on disabling COM 3,4,5,6,7,8,9 my programmer worked alright whereas there were 4 more ports (10,11,12,13) present on my computer.
- How this problem didn’t occur initially and has suddenly started coming.
Also I have observed that in my PC ports only COM1 is Communications Port all others are listed as blue tooth serial port (3,4,5,6,7,8,9,10,11,12,13)…
Can anybody help me out!!!!!
Thanku friends
Thanku friends
