pioneer head unit brake bypass
AJWatUC
I saw online I could use a relay to bypass brake switch on the pioneer head unit. I want use something smaller is there another way of doing this. this is how its wired to a relay-pin 30 green(parking brake) wire from radio pin 86 and 87 are Black (ground) wire pin 85 is Blue(remote) wire. So when I turn on the car the radio comes on then powers the remote wire which in turn grounds the parking brake wire from the radio. Any body have a suggestion
are you sure its not like a svc control, its a cortrol that varies the volume in relation to vehicle speed, but usually only on oem head units
They can have a mute line (sometimes called a phone mute) or a dimmer line from the dashlight controller.
To make the unit turn on you normally need 3 wires;
1. RED ign power or switched power (+12v)
2. YEL/RED or YEL battery power (always powered +12v)
3. BLA or BROWN is ground
What happens if you leave the wire coming from the head unit to parking brake permanently grounded? The radio turns on?
Is it a head unit with dvd player and screen? Mine require to be wire to the park brake because to have the dvd to work I have to apply the hand brake twice to confirms that I'm parked. You can use a small switch wired to ground to simulate your e-brake.
