The Q12 output divides the 8MHz clock by 2^12 so the period of Q12 is 512us..... You see? Yes the scope shows a period of 512us.........
So I guess we're set ? The problem was the hold off that was out of sync....
My problem started when I was building a circuit to generate composite video sync signals, and the circuit didn't work. Then I tried to work out the problem and disassembled everything and tried probing the counters, and then I saw those crazy waveforms and thought that was the reason why it didnt work.
So now that the counters are really fine, the problem is somewhere else. Probably my circuit contains logic hazards since it was asynchronous.
Do you use Skype or something? Id like to keep contact with you if you wanna be friends and talk electronics![]()
Ah that is good.
Thanks for the kind offer of a telephone contact, but I already have so much technical work that I would not be able to handle telephone calls- sorry PC.
By the way, I had to smile when I saw your post on ETO, because we had already discussed your counter on another forum.
spec
