Please Help Digital Clock Schematic Needed ASAP
bob_the_builder
Hi
If anyone would like to help and draw a schematic (preferable done on a computer) for a digital clock it will be greatly appreciated. The schematic is only for personal use. The schematic should be a 12 hour clock (including hours, minutes and seconds)
There is what the schematic should include:
- 6 number displays
- Use of transistors
- 7490 and 7447 chips
The 10th hour hand should no display anything until the value is 1 but the 10th min. can display a zero and so will the 10th second.
Thanks for you help, it is super greatly appreciated
bob_the_builder
Im a newbie here. I hd made 24hours clock base of 7490, 7447. But here in this forum had a post of that clock schematic. Mine has a little different of 4 transistor and one more for the second flicker. I go here to looking for a solution of preset buttons to adjusting the numbers. the glitching in a push button switch problem.
here the clock I made that doesnt have preset switch
here I post my simple design of 12hours with displaying numbers every 10 seconds for a minutes and 10minutes for an hour. Pulse at input is 1 Hz. May be this is the clock you mean.
Notes: every input pins of 7segments display that connected to 7490 should be add of 330ohm resistor.
Sory bob. theres something mistake in the schematic, U16 must be deleted and the 1Hz pulse shoud be connected to Clk1 of U13.
