hellow
how are you
i have programmed pic16f628a to perform asimple application which is lightining ALED at A0 output.
the problem is : the circuit works only if i touch the pins of the pic or any metalic part of the circuit .
also the voltage at pin A0 output is small about 2 volts( instead of 5 volt).
can you help me to solve this problem please?????
I HAVE MADE THE ENTIRE CIRCUIT ON ABREAD BOARD FOR TESTING PURPOSES.
how are you
