Please help me with this code....
asmpic
Hey guys, can someone please help me out with the following code. As of now it doesn't really do anything, I'm having problems with the code towards the end. For some reason, it doesn't want to subtract 'entered_pass_code' from 'something_clever' correctly. For example when entered passcode is 0x05 and something_clever is 0x01, it should execute the 'return' statement since the result of the subtraction is not zero, but instead it executes the 'match_found' line.
Any ideas??
	list P=16F84
	include	P16F84.INC
; Define the direction bit types
f	equ	1
w	equ	0
; Define the data storage locations
			org	0x20
counter			    res 1
counter_2		     res 1
entered_pass_code   res 1
num_pass_codes	   res 1
something_clever    res 1
			org	0x30
passcodes			res	8	;location of the program
; start defining the program
; no interrupts, so start at 0x0
	org	0x00
compare_to_list
	call	  indirect
	incf	  counter_2,f
	incf	  counter,w
	subwf	 num_pass_codes,f
	btfss	 STATUS,Z
	goto	  no_match
	goto	  compare_to_list
indirect
	movlw	  passcodes
   addwf     counter_2,w
   movwf     FSR
   movf      INDF,w
   movwf     something_clever
	movf	   entered_pass_code,w
	subwf	  something_clever,f
	btfss	  STATUS,Z
	goto	   match_found
return
match_found
nop
no_match
nop
end
Your program is behaving correctly, it is you who have the problem.
the instruction:
BTFSS STATUS,Z
translates to SKIP IF ZERO, since the Z flag is SET for a zero result.
If you want it to work the other way round you will have to use:
BTFSC STATUS,Z
