toprank
this guy here https://www.youtube.com/watch?v=QA7IclxN5YI
looks like he is using a crystal resonator, would i need that also?
ok great i thought that is what Pommie meant.
So all i need is micro controller, code and a power source to run the leds?
I know the LCD/keypad might need something else so i will look up tutorial.
the led will be connect by a 6-10 foot wire. whats the best language?
P.s. the 16F887-I/P is backordered.
Are you going to use standard LED's.?
Can you post a sketch, like to help, but its like bobbing for apples.
big neon lights would be cool but i think i want to build it with leds for now while i am learning.
P.s. DIP PIC16F877A-I/P - Is DIP ok for this project?
Reason for asking is the 10ft cable link from PIC to LED's.
If you are thinking about a later upgrade to Bigger/Brighter leds I would consider using ULN2803 drivers
between the PIC output pins and the LED's.
The ULN can accept PIC output levels and is able to drive loads upto +50V at a few hundred mA's.
