Please !!! Please !!! Please !!!
Wifilee
How to use counters to control 2 LEDs blink 5 seconds and 3 seconds respectively ? What kind of counter should i use ? synchronous counter ?asynchronous counter ? or other type of counter ?
PLEASE give me some information ..thank you
So you want two alternating LEDs, where #1 is on for 5 sec while #2 is off; and then #1 is off while #2 is on for 3 sec? (Wig-Wag)?
If so, I would use a 555 timer with a 5/3 duty cycle.
How accurate must the time be?
What supply voltage?
How much current do the LEDs require?
Or for more accurate timing, but more cost, use any small micro-controller such as 12F629.
actually my question is required the 5sec LED is represent flashing light ,3sec LED is represent warning bell, the 2 LED will be turned on when the train enters either from area 1 or area 3; and turn off when a train leaves the intersection. The flashing light and warning bell will turn on for 5sec and 3sec respectively when the train is in area 1 or area 3. Three signals P1,P2,P3 are generated when a train is in area 1 ,2 and 3 respectively.
i already know the 3 signals P1,P2,P3 is want to use flip-flop to control it , but i donno how to use counter to control the 2 LEDs blink 5 and 3 secs.
Question is required must use counters to keep track of time for the flashing light and warning bell signals.Use switches to simulate the presence of train in respective area.
