positive edged triggered SR latch or flip-flop?
danjel
Is there a standard part that exists where the S and R inputs are edge triggered (not level).
Typically only the CLK input is edge triggered on flipflops.
I only want these inputs to trigger a change in the input when they transition.
The only way I can think of doing this is to use a gate to pulse converter on the source signals so that they are only ON for a short period of time.
You could apply the S/R pulse to the FF input through a series capacitor, with a resistor connected from the FF input to ground.
Yeah I think this is the simplest solution. Alternatively I found this:
It uses two D FlipFlops for each SR flipflop
What about a J/K?
You do want the flip-flop to trigger on just one edge (slope) of the signal or both edges?
