Potentiometer with click at 0
m1tch37
Gday,
I am looking for a special potentiometer. The item i am looking for is often found on volume controls on mini radios and CD players. When you turn the volume down as far as it goes, you can feel the wheel click and the radio turns off.
Does such a item exist to a hobbyist?
Regards,
Mitch
You want a pot with a switch on it. They are commonly available. The switch is not electrically connected to the pot - only mechanically.
the click is sometimes called a detent too. like a pot for a balance control has a center detent between left and right, it's accomplished the same way, with a little addition to the shaft of the pot - could also be done with a notch in the shaft, a spring and a small bearing. when the notch aligns with the bearing, the spring pushes it in, slightly locking the shaft, so you have 'feedback'
i want to know the pot u had shown is which type of pot? is it resistance wound pot or which type????
A detent is not going to turn off the radio. You need a switch. I don't believe I've ever seen a pot with a single detent at one end of the rotation.
**broken link removed** has a list of different types of resistance elements. You can probably buy any of them with a switch mounted on them.
I don't know what kind of element the one in the picture has. I found it by doing a Google image search for "pot with switch".
Judging by the picture it looks like a carbon track element, noisy and not too reliable but cheap.
