Hero999 said:Why is that so?
Is it something to do the the voltage used?
ScuzZ said:Well with all the elements of the circuit staying the same, I still have not managed to get the relay to switch. It will switch with a current of 100mA, but alas I can not seem to get enough current without using three transistors.
Can anyone help?
ScuzZ said:Yes. That's the value I get. The probes are 0.4mm apart. Made of galvanised steel.
You just might be right about that, I'll have to give that a try.I thought carbon wat best since it's the most innert.
but even at 1 kHz it worked.t higher frequencies ad the ions might not have enough time to migrate
