superdhebz
Hi! Do you guys have a sample schematic diagram of a power supply with short circuit protection?
0 to 30 volts, 3 amperes.
The transistor is usually faster than the fuse.the best way to have some sort of short circuit protection, is to use fuses. 3 amps is a pretty common value you should be able to find one at a hardware store or at radio shack.
I assume you mean short circuit protection since that's not the same as over voltage protection.Just find a voltage regulator with built-in over voltage protection. There are lots available.
yes i did you must be psychic![]()
