kira_kame
PRESSURE Sensors HELP....
what kind of transistor or device or what ever thing to use in measuring pressure should i use???
*i am thinking in the lines of high air pressure measurements so its go to be durable...
*although not for under water usage im hoping for some water proofing and maximized anti corrosion protection since the moisture is a present factor in variable or changing air pressure environments....
*not for atmospheric or weather purposes....
*im also hoping to get micro devices somewhat as the same size of a match box pertaining to this sensor.... in short its not suppose to be THAT BiG.... just small enough....
