primary winding current.
True, I forget about core loss, transformers are still pretty much a dark art to me.
hi e86.
Look at this LTSpice plot of a transformer showing a Loaded and Unloaded secondary.
[the L3 inductor represents the transformer primary, with no secondary load]
Basically a transformer primary with a unloaded secondary is just an inductor.
hi e86.
Thanks!
The reason that in L1, the current doesnt lag behind the voltage is beacuse the load in the secondary circuit is a resistor?
Meaning, if this load wasnt a resistor, but a capacitor or another inductor, we would have seen a 90 degrees shift between Vp and IL1?
Thanks!
You can get a free download of LTSpice from the web.:)
With it you can set up most circuit conditions to check against your theory and calculations.
As you seem to be very interested in looking into the function of devices I would recommend you get LTSpice.
Many members use it and will on request attach a copy of a *.asc working file.
Its takes a little time to learn LTS but its worth the effort.
  • txr1.asc
Look at this sim.
A 1H inductor load and a 1000uF cap load.
  • txr2.asc
