Torben
Hi all,
Still working on my automatic printer control circuit.
Background: I wanted to be able to print without having to have to go boot up the Mac which is in the same room as the printer. So I put a print spooler on a TS-7400 board I had around (running Debian Linux 4.0) and am using that as a network print server. It works great but I want to have the thing obey the following rules:
o If a print job is detected, turn on power to the printer.
o If no print job has been detected for x minutes (x being configurable) then turn the power to the printer off.
So far, I have breadboarded the control software and circuit to control the 9V relay from the TS-7400's 3.3V logic outputs, and that all works great. I just hope someone can give me some more eyeballs on my schematic and board layout.
I am especially unsure about the snubber across the load. I think the values are pretty OK from what I've read, but I have not yet performed any spark tests with the printer's power cord so I don't even know whether it's necessary.
Also I wonder if running the coil for longish periods of time every so often (maybe a few hours on at the extreme) will be bad for it. I could go to a latching relay if this won't last long under typical home use. We don't print every day, or even every week.
Other things which might be useful to know: it's a Lexmark E232 laser printer, with the markings "600W 6A" on the back. The relay I am using is an SPST rated for 15A at 125VAC; the coil is rated for 9VDC.
Any problems/corrections/ideas welcomed!
Thanks,
Torben
Thanks,
Torben
