Problem in sending SMS through GSM module using 8051
ok now i decided that i will just check each command response
i read somewhere that gsm modem send OK for each successful retrieving of AT command
so i gust introduced serial interrupt for that and i am checking the response of "AT"
here is my code
#include"lcd.h"
unsigned char *command = "AT";
unsigned char CTRLZ = 0x1A, count;
unsigned char ar[5];
void serial_init(void);
void serial(unsigned char);
void puts(unsigned char *p );
void delay1(unsigned int);
void serial0() interrupt 4 {
if (TI==1) {
TI=0; //clear interrupt
else {
count=count+1;
ar[count]=SBUF;
RI=0; //clear interrupt
void main()
count=(-1);
init();
serial_init();
puts(command);
delay1(1000);
serial(CTRLZ);
print(&ar[0]);
while(1);
TMOD=0x20; //timer 1, mode 2(8-bit autoreload) to set baud rate
TH1=0xFD; //-3 to TH1 for 9600 baud rate
SCON=0x50; // 8 bit txion, 1 start 1 stop bit, REN enable for both txfr and rxve
IE=0x90;
TR1=1; // start timer
void puts(char *p)
char *temp = p; /*temp pointer so that the actual pointer is not displaced */
while(*temp != 0x00)
serial(*temp);
temp++;
void serial(unsigned char x)
SBUF=x;
while(TI==0);
TI=0;
void delay1(unsigned int x)
{ int i,j;
for(i=0;i<x;i++)
for(j=0;j<1275;j++);
lcd.h header file contains this code:
#include<reg51.h>
sbit rs=P3^3;
sbit rw=P3^4;
sbit en=P3^5;
void dat(unsigned char);
void cmd(unsigned char);
void delay(unsigned int);
void print(unsigned char *);
void init();
void num(unsigned int);
void init()
cmd(0x38);
delay(100);
cmd(0x0E);
delay(100);
cmd(0x06);
delay(100);
cmd(0x01);
delay(100);
cmd(0x80);
void cmd(unsigned char x)
P2=x;
rs=0;
rw=0;
en=1;
delay(1);
en=0;
void dat(unsigned char y)
P2=y;
rs=1;
rw=0;
en=1;
delay(1);
en=0;
void delay(unsigned int z)
int j,i;
for(i=0;i<z;i++)
void print(unsigned char *p)
while(*p!='\0')
dat(*p);
p++;
why iam not getting the "OK "on LCD?
If you do not get an OK from "AT" then nothing's going to work... The last time I dabbled in GSM, I hooked it up to a PC and got the commands working with 3 wire 9600,8,n to start with.... I cannot find the proper AT command set... I have only the extended AT set....
https://www.google.com/url?sa=t&rct...=q_qqV-XbrV97-T019UWLFQ&bvm=bv.92291466,d.d2s
Its quite intense but some good info in there... Is it possible to hook it up to your PC and get it working with hyper terminal or similar...
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0CDAQFjAC&url=https://download-c.huawei.com/download/downloadCenter?downloadId=14254&ei=MYVEVfaFFcraaMGcgfAF&usg=AFQjCNEMzu0fRDIXMPk4PMEyeo3h_meEkQ&sig2=q_qqV-XbrV97-T019UWLFQ&bvm=bv.92291466,d.d2s
thank you sir,
i am using GSM module sim900A of Sim comm. company
isn't there any difference of working ?
will this article help me for this module?
GSM900/a is the model.... The actual modem is a Huawei EM820... So that's the datasheet to access AT command set...
As I said.... Get it up and running on a PC first...Open a terminal program and type "AT" and see if it replies.... If it does then you know its software on your part!!!
yes it didn't worked...
and i meant that i am not getting your code... i am not familiar with that #ifdef code lne
It just stops that part of the code being run because I wanted to mimic the Arduino code example exactly. Not really important.
But calling works, and he's done it on Arduino as well? Apparently anyway.
