yusuf
Hello friends !
I have attached the required circuit diagram in my attachment !
Here in my circuit diagram you see that there is three water
sensor !
I have added the wire at the water sensor's sensing point to
sense the water. It is sensing water and working properly with
3 meters wire...
My tank is located on the top floor, the distance from ground
floor (where I want to place this circuit) is at least : 10 meter.
I want to add 10 meters wire at sensing point so sense the water from top floor.
I have tested by adding 10meter wires but the circuit was not working properly
it was false triggering !
So I have done several test and at last I came to 3 meters... It was working
properly with 3meter ....
Please help I want to add 10 meter wires at sensing point to sense water from my top floor...
I have attached the circuit diagram , please have a look !
Please zoom the circuit diagram for better and clear vision !
Help required friends :
Thanks in advance !
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
sensor !
3 meters wire...
Thanks in advance !
