Problem with PIC digital input output
sahu
I tried to use the below given code to PIC 16F72.
#include <htc.h>
#include <PIC16F72.h>
    __CONFIG(FOSC_HS & WDTE_OFF & PWRTE_OFF & CP_OFF & BOREN_ON);
#define _XTAL_FREQ 4000000
#define HI_CUT 208//adc=245*17/20    //250
#define OLD 100
#define LO_CUT 60
#define NORMAL_LED     RA5    //RB1
#define ERRORE_LED     RA4
#define OP_LOAD_RELAY     RA3    //RB2
#define C_100    RB5
#define C_10    RB6
#define C_1        RB7
void main()
  TRISB = 0x01;
  TRISC = 0x00;
  TRISA = 0xC7; //RA0 to RA2 as adc & RA3 to RA5 as o\p
  GIE = 1;
  PEIE = 1;
  T0IF = 0;
  OPTION_REG = 0x07;
  T0IE = 1;
  TMR2IE = 1;
  TMR2IF = 0;
  TMR1IF = 0;
  TMR1IE = 1;
  T1CON = 0x34;
  INTF = 0;
  INTEDG = 0;
  INTE = 1;
  T0CS = 1;
  NORMAL_LED = 1;
  ERRORE_LED = 1;
  OP_LOAD_RELAY = 0;
  C_100 = 1;
  C_10 = 1;
  C_1 = 1;
  ADC_Init();
BUT RA3 & RA5 are not Work as output. Can anyone tell why?
where i has wrong ?
but when i use as below
#define NORMAL_LED RB1
#define OP_LOAD_RELAY RB2
work fine .
According to the ADCON1 register... That combo isn't possible...
The closest is ADCON1 = 0x04.. That gives AN0, AN1, AN3, and AN2 / 5 as digital... so you'll have to swap AN2 and AN3
now i'm using ADC_Init as below given code
void ADC_Init()
  ADCON0 = 0x81; //ADC Module Turned ON
  ADCON1 = 0x00;
char ADC_Read(unsigned char channel)
  if(channel > 7) //If Invalid channel selected
    return 0;     //Return 0
  ADCON0 &= 0xC7; //Clearing the Channel Selection Bits
  ADCON0 |= channel<<3; //Setting the required Bits
  __delay_ms(2); //Acquisition time to charge hold capacitor
  GO_nDONE = 1; //Initializes A/D Conversion
  while(GO_nDONE); //Wait for A/D Conversion to complete
  return (ADRES); //Returns Result
You can't have that combination!!!!!!
If ADCON1 = 000.. All PORTA will be analogue input.
If ADCON1 = 001.. All PORTA will be analogue input and RA3 will be Vref.
If ADCON1 = 010.. All PORTA will be analogue input.
If ADCON1 = 011 . All PORTA will be analogue input and RA3 will be Vref.
If ADCON1 = 100.. RA0, RA1 and RA3 will be analogue input RA2 and RA5 will be digital.
If ADCON1 = 101.. RA0 and RA1 will be analogue input and RA3 will be Vref.. RA2 and RA5 will be digital.
If ADCON1 = 111.. All PORTA digital.
These are the only combinations
RA4 can't use as digital?
