Billy Mayo
Why not use a zener diode or a resistor voltage divider as a voltage reference?
when you separate the voltage ref input and the control output.
And what can you do when you do this?
That is not true at all
Perhaps he just doesn't want the thread to stop.![]()
It sounds like it keeps a REF at 2.4 volts and it compares it will the VCC +5 volts , it's a comparator with a REF at fixed 2.4 volts as a Reference compared to the external resistor
Op-amps and comparators are very similar. In some cases you can use them interchangeably. I tend to think of the TL431 as containing a comparator due to it's open collector output. The block diagram does show it as an op-amp driving a transistor. I apologize for any confusion that I gave by calling it a comparator.
In the case of the TL431, it doesn't amplify the reference voltage. It amplifies the error between the internal reference voltage and the voltage at the REF pin.
Maybe a non-electrical example might help you to understand it.
Consider you are driving you car down the road. Your mind wants to go at 60 miles per hour (or whatever the unit of distance is where you are). This represents the internal reference voltage (2.5V). The speedometer of the car says you are doing 70MPH (the voltage at the REF pin is greater than 2.5V). Your brain (the comparator) sees that the car is going too fast, so it tells your foot (the cathode pin) to let up, sending less gas to the engine. If the car is going to slow, the same process will result in more gas being sent to the engine. If you are going at the speed you want, it will make no change in the gas feed. But as soon as external changes affect the speed (going up a hill) an error is detected, and the gas feed is changed.
This is how the TL431 is usually used in a power supply. It looks at a sample of the output voltage (via a resistor divider feeding the REF pin) and decides if the power supply engine needs to work harder, less hard, or stay the same, in order for the voltage to be what it is supposed to be. This error signal is communicated to the power supply controller by a change in current drawn by the cathode pin of the TL431.
